Is there a Diablo Predator tuner for a 98 Z28?
Originally Posted by ARCTICWHITE98Z28
I have looked for a Diablo tuner for my 98 Z28 and it looks like they don't make one for that year. Is that true?
if you knew about the 1998's then you would know that the ecu is completely different than the 99-02, which is why it does not work.
The hardware is the same, but the software put on the 99-03 ecu's are different. 2004 goes to a 1mb flash, vs the 512K that the 99-03 ls1 ecu;s use so good luck with that
Ryan
Ryan
