Injector flow question
Old Sep 22, 2005 | 04:13 PM
SSpdDmon's Avatar
Default Injector flow question
A friend of mine has a '99 with the smaller injectors. He recently bought some lightly used 28# injectors (off of an '01 or '02 I think). Can I just copy my injector flow table from my '02 and paste it into his tune so his car can accept the larger injectors? Are there any other tables that need to be adjusted?
Old Sep 22, 2005 | 05:59 PM
2xLS1's Avatar
Offset vs Volts vs KPA
Old Sep 22, 2005 | 06:05 PM
RedHardSupra's Avatar
yup, 28.8s are just that, as long as you're running them at the same fuel pressure
Old Sep 23, 2005 | 05:22 PM
Viper's Avatar
"Offset vs Volts vs KPA"
I just checked my stock 99 file vs. stock 98 and that table is different. And the stock Z06 02' is different as well. Both the 98 and 02 have 28lb.
To date I've only changed the injector flow table for my 42lb SVO's, and didn't touch the Offset vs Volts vs KPA table.
Do I need to?
Old Sep 23, 2005 | 06:32 PM
2xLS1's Avatar
The 98 and 01,02 injectors are not exactly the same even though the IFR tables seem to be. 98s are supposedly 28.6#/hr and 01,02s are supposedly 28.8#/hr. They have different GM part #s also. LS6 injectors look to be somewhere around 29.3#/hr but I've never heard for sure. The Offset vs Volts vs KPA tables should be different with different size injectors.
Old Sep 24, 2005 | 08:02 PM
SSINFUL's Avatar
Which way to multiply: Up or down? By # greater than 100% or lesser than 100% for BIGGER injectors than stock? (This item "compensates" for time delay in opening the injector?)
Thanks-
Old Sep 24, 2005 | 08:17 PM
2xLS1's Avatar
Look at the Offset vs Volts vs KPA on a 99 (26.8) and a 02 (28.8) and you will see it is not a linear difference. Some values are higher and some are lower when comparing the 2 tables. I don't think you can say you just multiply the table by a straight percentage. If you are talking about the IFR table, then yes, you just multiply by a straight percentage.
Old Sep 24, 2005 | 08:26 PM
SSINFUL's Avatar
The Injector Flow rate table: Again, which way to multiply there? I got one feller telling me to multiply to a lower % for a bigger engine and bigger injectors: 455 w/ Bosch 36 LBers. Shouldn't that be higher? Obviously, I'm looking to run a little rich, right?
Thanks again-
Old Sep 24, 2005 | 08:33 PM
2xLS1's Avatar
New injector size/Old injector size = the multiplyer you use if the injectors have the same Bar (psi) rating. Size of the engine has nothing to do with it. Or just use the attached file.
File Type: zip
Old Sep 24, 2005 | 09:27 PM
SSINFUL's Avatar
Okay, a little better. I've got 3 Bar injectors. Per yer chart that's = to 43.5 PSI. The LS1 is @ 58 PSI. That's 33.3% more. So, I guess they're not really 36 LBers. Closer to 48 LBers @ LS1 fuel pressure. That's 66% bigger than stock. Wow. Or, should I say "Ow". Is this a problem?
Old Sep 24, 2005 | 09:34 PM
2xLS1's Avatar
I get around 41.8/4 bar using the excel file.
Old Sep 25, 2005 | 11:25 AM
SSINFUL's Avatar
Okay, I looked it up. It's what I thought. 1 BAR = an atmosphere at sea level or 14.7 lb/f or 1 bar = 100 kN/m². So, why wouldn't my previous math apply? If 3 BAR = 43.5 (acually, why wouldn't it be 44.1?), then why can't 58 PSI work out to 48 PSI for 36 LB injectors? Is there a variable?
Old Sep 25, 2005 | 11:50 AM
slow's Avatar
Injector flow rate equation is:
new flow rate = Old Flow Rate * Square Root (new pressure drop/old pressure drop)
Ryan
Old Sep 25, 2005 | 12:01 PM
how about just using the injector spreadsheet in the stickies of the PCM section, to calculate the table for the new injectors, not just modify the old values (which assumes that all injectors scale the same)?
Old Sep 25, 2005 | 01:41 PM
slow's Avatar
I was just giving the math behind the injector flow rates, and why it is not linear like the above posted though.
The spreadsheet is very nice I keep a copy of it in my tuning tools folder.
Ryan
