DTC Accumulation
Old Oct 4, 2005 | 08:48 PM
Spenser309's Avatar
Default DTC Accumulation
I have about 50 DTC's showing on my car right now. Kinda pisses me off because I know that most of these aren't problems. If i was to clear them the ones that are actually still problems would come back right?
Old Oct 4, 2005 | 09:00 PM
horist's Avatar
if the PCM detects a problem it sets an SES on the first or second notice of it
If the PCM detects that the problem is fixed, it will eventually turn off the SES
If you're setting 50 DTCs it sounds like a big problem ... or the potential of being one... I'd suggest posting up what you're setting
Old Oct 4, 2005 | 11:37 PM
Spenser309's Avatar
alright here we go.
DTC’s
P0102-
P0103
P0135
P0140
P0154
P0155
P0160
P0200
P0300
P0336
P0405
P0412
P1637
Other DTC’s not ran or something
P0101
P0141
P0161
P0171
P0172
P0174
P0175
P0401
P0404
P0410
P0420
P0430
P0440
P0441
P0446
P0506
P0507
P1416
P1441
P1539
P1546
Old Oct 5, 2005 | 04:42 PM
Spenser309's Avatar
any ideas? my car has no egr or Air.
Old Oct 5, 2005 | 10:24 PM
tars7's Avatar
did you take out your cats? or have your car tuned after you took out the EGR and AIR?
Old Oct 5, 2005 | 10:29 PM
HumpinSS's Avatar
Originally Posted by Spenser309
alright here we go.
DTC’s
P0102- Maf sensor circuit low
P0103- " high
P0135- o2 heater performance bank 1
P0140- " bank 2
P0154- o2 insuffiecinet activity bank 1
P0155- heater performance bank 1
P0160
P0200
P0300
P0336
P0405
P0412
P1637
P0101
P0141
P0161
P0171
P0172
P0174
P0175
P0401
P0404
P0410
P0420
P0430
P0440
P0441
P0446
P0506
P0507
P1416
P1441
P1539
P1546
you have a whole bunch of o2 related codes with egr looks like you need a tune if the egr is removed and new o2 sensors for the from. Something is wrong with you MAF sensor. you are idling to high and too low (iac motor may be broke.
or
you just have a bad ******* ground. Make sure the pcm isn nice and tight
Old Oct 5, 2005 | 10:58 PM
Spenser309's Avatar
could a stereo system that can bring the voltage down to 11.5 volts cause the problem. How would i find out what is wrong with the MAF? Also both my cats are gone and the rear o2's are gone. im getting bad mileage too.
