FlashScan V2 Pictures and Info
Old Oct 7, 2005 | 10:30 PM
JGA's Avatar
JGA
Hi
I agree I should know this stuff. I think I will bite as soon as it is available.
JA
Old Oct 7, 2005 | 10:41 PM
BLASTER's Avatar
Originally Posted by EFILive
FlashScan V2 has everything that FlashScan V1.2 has and more.
Yes, it has black box logging. There are now no time restrictions, you can log for days if you want to.
It also has 4 analog inputs for wideband and other sensors.
It has 2 new 12V analog inputs for 12v sensors.
All analog inputs have their own ground pin so ground offsets issues will be a thing of the past.
It has 2 thermocouple inputs so you can measure temperature differences such as IAT temps before and after compression or before and after intercooling.
Regards
Paul
I am glad to see you guys increased the numbers of A/D inputs. I was actually just going to ask about this until I saw this post. I have an immediate need to hook up a dual wideband but don't want to limit myself in the future. Great work.
Out of curiosity, what are some examples of 12 volt sensors that one might hook up?
Very nice.
Should i wait for the V2 or get the V1.2 and upgrade later. I mean if i get the commerical 1.2 FlashScan would the upgrade be just the difference in price between the two? So if V1.2 is $849 and the other one lets say $1049 that means i just upgrade for $200 only?
I am in the same boat and would like to know this as well. Thanks.
Old Oct 8, 2005 | 12:43 AM
EFILive's Avatar
Restricted User
You can use the 12V inputs to capture/log any voltage level in the vehicle up to 12 volts. (Actually I think they go up to 18 volts since some voltages in the vehicle are >12V.) What we had in mind when adding those inputs, was using FlashScan V2 as a digital multimeter and possible even as an digital oscilliscope. The A/D converters can process signals up to 1 MHz. I am not an electronic engineer so I won't go into any details or I'll end up saying something stupid. (I probably already have).
The upgrade price will be fair and reasonable, but since we have not even started to discuss what it will be, it would be premature of me to speculate right now.
Regards
Paul
Old Oct 8, 2005 | 07:23 AM
TAQuickness's Avatar
Old Oct 8, 2005 | 10:14 AM
FastFieros's Avatar
Well this did not just happen overnite. Great work guys !
Loyde
Old Oct 8, 2005 | 10:54 PM
MNC5's Avatar
Very slick, is that available through your website? I never saw it in the store ect..
Nice Piece BTW
Old Oct 8, 2005 | 11:02 PM
foff667's Avatar
LS1TECH Sponsor
they are projecting availability nott until 06'
