Knock Retard
teh knock sensors are not just looking for loud noises...
they are loking fo ra very specific noise...
a noise that can only be caused by knock or ping
The knock sensor is tuned to a specify frequency, like a tuning fork. When this frequency is applied to the sensor (through its connection to the engine), a peizoelectric crystal inside the sensor generates a small voltage (~1 volt), much like a microphone. As an example, some Corvette knock sensors (GM PN 1997562, 1997699, OR Standard Motor Products KS45, KS46, KS49, or KS117) had a design frequency of 5200 hertz, and they would produce a signal between 4800 rpm and 5600 rpm
