voltage on stock 02s
Old Oct 9, 2005 | 01:11 PM
zrater's Avatar
Default voltage on stock 02s
does heat make 02s be higher in voltage.
Old Oct 9, 2005 | 01:35 PM
bowtieman81's Avatar
Not sure I understand your question, but O2 sensors report a voltage based on the oxygen content in the exhaust, not heat.
Now, the sensors do require a warm up period when you start the car when their reported voltage will not be accurate.
Old Oct 9, 2005 | 08:33 PM
zrater's Avatar
after making a couple of back to back runs it seams the 02s peak in a diffrent
spot at wot , is that because there alittle hotter after the first run.
Old Oct 9, 2005 | 10:44 PM
What do you mean by peak? At WOT your O2 sensors will be ~890 mV, and will stay there while in PE mode.
Old Oct 9, 2005 | 11:09 PM
luv2spd's Avatar
The higher the mV on the 02 the richer the afr mixture is. So to answer your question heat makes them read lower.
Old Oct 10, 2005 | 09:03 AM
jimmyblue's Avatar
Moderator
There is a minimum temp below which the output
voltage will be depressed (the chemical cell needs
to be pretty hot to make output). So between cold
and some minimum working temp, more temperature
will increase the output. I do not know what this
minimum temp is, but cold output is zero....
However, above 500C or so further increase in sensor
temp -decreases- the rich output voltage. This effect
is in fact stronger than the effect of changing mixture,
at lower AFRs.
Old Oct 10, 2005 | 03:42 PM
zrater's Avatar
thanks jimmy temp does effect them, the hotter the less voltage. three runs
and they started at 920, 900, 880, as temp went up the voltage came down.
i think exhaust was at 850 degrees on scan tool.
