Strange LTFT problem
Old Oct 10, 2005 | 09:07 PM
Roy V.'s Avatar
Default Strange LTFT problem
This is driving me nuts.
Leaving the car in park or neutral, both LTFT's run up to 24.9 and I get a 171 and 174 code. If I put the car into drive, reverse or any gear, both LTFTs instantly decline to 16 or 17. This change is instant - did drive/neutral several times and the same thing. There is no change in engine sound or anything else other then the idle decreasing a bit when going from neutral to drive. Any thoughts on this would be greatly appreciated.
Thanks,
Roy
Old Oct 10, 2005 | 09:14 PM
P Mack's Avatar
Park and drive use different fuel trim cells, so the instant change is normal. You're ltfts are very high though, have you messed with your ve table before?
Old Oct 11, 2005 | 09:21 AM
Roy V.'s Avatar
Thanks for the response - I haven't messed with the ve table, I would hurt myself if I did. I just find it strange this problem started out of the blue.
Roy
Old Oct 11, 2005 | 09:31 AM
NOSjohn's Avatar
Restricted User
You haven't changed anything on the car? Air filter dirty ? Try and clear them and see if the re-learn to a better number.
Old Oct 11, 2005 | 09:38 AM
jimmyblue's Avatar
Moderator
I believe a stock VE table against that cam would
produce negative trims (VE being degraded at idle,
not represented, making positive airflow calc error
and overfueling). Trims are indicated postive.
My suspicion is that the headers are driving false
trimming, that the drive LTFTs are better because
that trim cell encompasses some higher load, hence
higher exhaust heat, making the quality of trimming
better (not good, just better).
The first thing to do is to look at the idle O2 real
time waveforms and determine whether the O2s are
working well, or just barely hanging on. That's the
basis for all trimming and it wants to be happy.
The codes are just griping that LTFTs are bumping
over +25
Old Oct 11, 2005 | 09:51 AM
NOSjohn's Avatar
Restricted User
Ha - I like the analogy: sleepy vs. happy. Does that count even at idle or is that at load?
