Help with system requirements for HPTuners
Old Oct 13, 2005 | 03:51 PM
Anniversary "Z"'s Avatar
Default Help with system requirements for HPTuners
Can someone give me a clue to the requirements a laptop needs to run HPTuners? Like wise the ports that are needed?
Thanks
Old Oct 13, 2005 | 04:00 PM
00Z28SS's Avatar
Very little is needed as far as system requirements to run HPTuners. In fact older laptops work better because they have the 9-pin connector needed to interface with the pcm, most newer laptops do not use 9-pins anymore. Also, you need a Windows 98 or better OS, at least a 300 MHz processor and 64 MB of ram.
Old Oct 14, 2005 | 04:55 PM
Thank-you that is exactly what I was hoping for!
Old Oct 14, 2005 | 05:23 PM
foff667's Avatar
LS1TECH Sponsor
Minimum
350 MHz CPU
64 Mb RAM
Microsoft Windows® 98
Serial Port* (Version 1 Serial Interface Only)
USB Port (Version 2 USB Interface Only)
Recommended
650 MHz CPU
128 Mb RAM
Microsoft Windows® 2000/XP
thats from the 2.0 help file
Old Oct 14, 2005 | 09:36 PM
jimmyblue's Avatar
Moderator
I have done OK with a 266MHz ThinkPad but it needed
its memory maxed, to hang tough. Dell laptops with DB9
serial ports ran up through at least the 1GHz range and
I just got one off eBay for $420.
HPTuners 2.0 will have USB as an option for new hardware
shoppers. But USB is needier and makes the MHz required,
higher. I guess. Though after frying the serial port on the
Thinkpad I've been logging with a Wal-Mart USB-Serial
dongle without any trouble. Haven't tried any of the high
speed stuff though.
Anyway, cheap is where it's at. Too cheap, is anything
less than my setup.
