Aleviate bucking not with spark but with fuel...
#41
Originally Posted by WS6FirebirdTA00
what rpm range does this happen and at what load? im working with throttle cracker tables right now to see if that will help but it didnt seem to do much of anything. how high and low have you gone on timing?
As far as timing, My idle is usually around 30 degrees. Ive tried slowly going up to 32, 34, 36 etc. Ive also tried very agressive timing going to 40+ right off idle. Currently Im fairly high, but loosely following the curve of the stock timing table.
Current Top Left portion:
30 30 30 30 30 33 35 41 47 48
31 32 32 33 33 36 38 42 47 48
32 33 35 36 37 39 40 43 47 47
32 35 37 39 41 42 43 44 45 46
30 33 35 37 39 40 41 43 43 44
28 31 32 35 37 38 40 41 42 42
27 28 30 32 35 37 38 39 40 41
26 27 28 31 33 35 37 38 40 41
#43
im having it about the same area...and obviously its happening with good and shitty tunes....i've always thought there was something else that played a role in it, but i dont know all this **** well enough to figure it out. you mentioned working on the throttle cracker. what about the torque timing or whatever its called?? i dont have the program here in front of me to see what the actual name is right now.
#44
mine goes from 28 up to 44 with 36/41 at 1200/1600, 44 is at 2200
28 28 28 28 36 39 41 43 45 46 47 47 48 48 48 47 47 47 47 47 47 47 47 47 47
29 30 30 31 36 39 41 43 45 46 46 47 47 47 47 47 47 46 46 46 46 46 46 46 46
30 31 33 34 36 39 41 43 45 45 46 46 47 47 47 47 46 46 46 45 45 45 45 45 45
30 33 35 37 39 40 41 42 43 44 44 45 45 45 45 45 45 44 44 44 44 44 44 44 44
27 30 32 34 36 37 38 40 40 41 42 42 43 43 43 42 42 42 41 41 41 41 41 41 41
25 27 29 32 34 35 37 38 39 39 40 41 41 41 41 40 40 40 40 40 40 40 40 40 40
24 25 27 29 32 34 35 36 37 38 39 40 40 40 39 39 39 39 40 40 40 40 40 40 40
23 23 25 28 30 32 34 35 37 38 38 39 39 39 38 38 38 39 40 40 40 40 40 40 40
22 22 22 25 27 30 32 34 36 37 38 38 39 38 38 37 37 38 39 39 39 39 39 39 39
20 20 20 23 26 29 31 33 34 35 36 37 38 38 37 37 37 37 38 38 38 38 38 38 38
18 18 18 21 24 26 28 30 33 34 35 36 37 37 37 36 36 37 37 37 37 37 37 37 37
16 16 16 20 22 24 26 27 29 30 31 33 33 33 33 33 34 34 34 34 34 34 34 34 34
14 14 14 17 19 20 21 22 23 24 26 28 30 31 31 31 31 32 33 33 33 33 33 33 33
14 14 14 17 17 18 19 20 21 22 23 24 25 28 29 30 31 32 32 32 32 32 32 32 32
14 14 14 16 16 16 17 18 19 20 21 22 24 25 27 29 30 31 31 31 31 31 31 31 31
14 14 14 14 14 14 14 15 16 18 20 22 24 25 26 27 28 28 29 30 30 30 30 30 30
14 14 14 14 14 14 14 15 16 18 20 22 24 25 26 27 28 28 29 29 29 29 29 29 29
14 14 14 14 14 14 14 15 16 18 20 22 24 25 26 27 28 28 28 28 28 29 29 29 29
14 14 14 14 14 14 14 15 16 18 20 22 24 25 26 27 28 28 28 28 28 28 28 28 28
#46
yeah that looks good, i sent the bin out last night, ill try to resend it when i get home, just hit me up on aim and ill try again, but yeah all these changes are in there
