runs like ass in SD when cold
Old Oct 24, 2005 | 07:44 PM
Red99TA's Avatar
Default runs like *** in SD when cold
I'm trying SD for the first time and in the process of learning fuel trims. Is it normal for the car to run like total crap when it's cold. Once it's warm and goes into closed loop it runs great but up until then it hesitates and backfires like crazy...is this normal?
Old Oct 24, 2005 | 07:52 PM
TAQuickness's Avatar
yes. more than likely your open loop table is to rich. A WB would really make your SD tuning a lot easier.
Old Oct 24, 2005 | 08:16 PM
Black02SS's Avatar
Add 10% from your open loop air fuel table making it richer from 176*F and below. This will help part of the problem. A wideband will help the rest.
Old Oct 27, 2005 | 08:11 PM
Red99TA's Avatar
So I need to add fuel or take some out?
Old Oct 28, 2005 | 06:30 AM
Black02SS's Avatar
Well I must of been about half asleep when I wrote that. You need to make the car leaner. Sorry for the confusion. I would remove 10% to start with.
Old Oct 28, 2005 | 07:26 AM
Hey Black - Beer's not just for breakfast anymore
Old Oct 28, 2005 | 07:55 AM
Black02SS's Avatar
It is when you work midnights.
Old Oct 28, 2005 | 07:57 AM
Black02SS's Avatar
And just for the record, if you add 10% to that table it will in turn take fuel out.
13.0 + 10% = 14.3
I was half right.
Old Oct 28, 2005 | 08:07 AM
Patrick G's Avatar
LS1 Tech Administrator
The open loop fueling table is like a PE multiplier. The higher the number, the richer you'll be. I've leaned my table out a bunch. My startups are not near as stinky as they used to be.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 28, 2005 | 08:11 AM
Black02SS's Avatar
Yup, I was thinking of both the multiplier and how we can see the actual AFR in EFILive. If it is displayed as a multiplier ie 1.00 subtract to go leaner
If it is displayed as an actual AFR, ie 13.0 add to go leaner.
Hope that takes the confusion out of it.
Old Oct 28, 2005 | 10:49 AM
T/A rocker's Avatar
When y'all say the "open loop fuel table", you are referring to the secondary VE table?
Old Oct 28, 2005 | 10:54 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Nope...the "Open Loop F/A" table. Not the same as the VE table(s).
Old Oct 28, 2005 | 12:38 PM
table b3605
Old Oct 28, 2005 | 03:08 PM
Red99TA's Avatar
If I understand it right HPTuners divides the commanded AFR by whatever number is in the table so I need to make the numbers smaller so that the AFR goes up (leaning it out). Is this right?
Old Oct 29, 2005 | 06:27 AM
MeentSS02's Avatar
Yes. It is just like the PE table.
Old Oct 29, 2005 | 06:28 AM
MeentSS02's Avatar
Oh, and FWIW, the richest mine ever goes is like 13.0:1 (I think) on startup...that's plenty rich.
