Using LT1 Edit, how do you turn off the knock sensor?
Old Nov 1, 2005 | 05:07 PM
matt94z's Avatar
Default Using LT1 Edit, how do you turn off the knock sensor?
I'm picking up false knock. Help me turn the knock sensor off. Thanks in advance.
Old Nov 1, 2005 | 06:10 PM
2xLS1's Avatar
Easiest way to completely disable them is set Max Retard Not In PE, and In PE tables to 0. If you want to desensitize them, use the KR Attack and KR Decay tables. The help files will tell you which way to move the values for each table.
