Problem after header install!! keeps throwing codes
Make sure none of the wires are resting on the collectors either. That was my problem. The moment they got pulled away everything went fine. Could be the heat on the spliced wires in your case as well.
did they looks like the center wire in this picture? so you did not cut any wires?
so have you noticed any exhuast leaks around were the header meets the head? lean code is for low mv output from the o2 sensors. what header gaskets did you use? if you used anything other then the stock GM gaskets then that might be your problem
...but that was because it took him a while to find out why it kept on going back to running like crap. Hope that helps.
