Open loop always?
Old Nov 4, 2005 | 05:10 PM
oange ss's Avatar
i can understand the OLFA tables at cold temps/low MAP, but why have it a higher temps/higher MAP when PE should be commanding anyway ?
Old Nov 4, 2005 | 05:22 PM
Black02SS's Avatar
If you are refering to my table, I have PE disabled.
Old Nov 4, 2005 | 05:50 PM
oange ss's Avatar
i'm refering to OLFA in general, why high ECT/MAP tables when PE should be commanding anyway ?
Old Nov 4, 2005 | 08:13 PM
soundengineer's Avatar
Originally Posted by MeentSS02
No worries man...I'll bet I can figure it out from the screen captures you put in the other thread...there are more important things in life than this stuff
Old Nov 5, 2005 | 12:13 AM
mattsls1's Avatar
I guess we'll see tomorrow how the tune goes? Thanks SE!
Old Nov 5, 2005 | 09:05 AM
oange ss's Avatar
Old Nov 5, 2005 | 09:10 AM
for reference....teh computer commands whichever is the richer of the 2..OLFA / PE
it always commands whatever it finds to be the richest
Old Nov 5, 2005 | 10:25 AM
oange ss's Avatar
I understand how it's used but why have it at all for anything other than cold start open loop ? Why have 2 open otables that do the same thing (PE,OLFA) ?
Old Nov 5, 2005 | 12:30 PM
becasue PE doesnt command anything at part throttle...and as my reference above to teh supercharger guy who takes of quick on a cold start...and he runs way lean until it gets warmed up.....and then PE will be correct because fo the adder
Old Nov 5, 2005 | 12:33 PM
oange ss's Avatar
why would you need open loop at part throttle ?
Old Nov 5, 2005 | 12:57 PM
Black02SS's Avatar
Open loop is designed as a fail safe from what I understand for if your O2's malfunction, it reverts back to a safe AFR. If you have lazy/sleepy o2's, they aren't as accurate so you eliminate the problem. Switch to open loop where you have a more consistent way of fueling.
Old Nov 5, 2005 | 02:58 PM
  #32
also your car remains in open loop until you get up to a certain operating temperature...defined in the closed loop vs ect table
