Please help codes after header install!!!
Old Nov 3, 2005 | 05:23 PM
red6speedss's Avatar
Default Please help codes after header install!!!
I installed pacesetter LT headers on my 00ss. I did use the o2 extensions in. I had tghe rear o2 codes deleted. I am getting the codes P0153B( slow response Bank 2 Sensor 1? and P1133B( Insufficent switching Bank 1 sensor 1) What is causing these codes? How can I fix them? Should I just delete them? I read about using the rear corvette o2s, would this fix my problems? thanks, Brett
Old Nov 5, 2005 | 08:10 PM
will putting the vette rearo2s # 13111 solve my problem, or should I just delete the codes?
Old Nov 5, 2005 | 09:55 PM
jimmyblue's Avatar
Moderator
The codes are telling you the headers are too cold
for the sensors to work. If they don't work your
fuel trimming will be messed up. Try the hot sensors
and maybe other thermal measures.
Old Nov 6, 2005 | 03:29 PM
Bill Bowling's Avatar
Talking
Mine were fixed by using the Bosch 13111 O2's.
Bill
Old Nov 7, 2005 | 02:53 AM
I am going to try the vette o2s. If that doesn't work, what else can I try? thanks, Brett
Old Dec 2, 2005 | 08:18 PM
Pavetim's Avatar
I put those bosch sensors on mine and I get the codes too. Not sure what i'm gonna do yet, probably wrap the headers.
Old Dec 3, 2005 | 08:53 AM
hawaiiboysz's Avatar
So if your headers dont get up to a certain temp then you will throw codes? My car has SLP headers on them now. I know SLP but I bought it with them installed and are throwing codes out for switching etc. Damn I better try them vette ones too.
