shift light
Old Nov 12, 2005 | 04:22 PM
WS6nJAX's Avatar
Restricted User
Default shift light
did my install on the harlan shift light and can not get it to respond. power side if fine. it will let me set the cyl # and rpm buttons w/flash indication. but no response to any rpm setting. should i be getting some sort of reading from the tach line ( white wire/ # 10 pin ) that i could check with a test light?
Old Nov 12, 2005 | 05:13 PM
Phoenix 5.7's Avatar
how many cyliders did you set it at. idk about the harlan, but i think some of the shift lights/tachs need it set at 4 cylinder for some reason with LS1
Old Nov 12, 2005 | 08:48 PM
WS6nJAX's Avatar
Restricted User
i set mine at 8 like the instructions said.
Old Nov 12, 2005 | 09:35 PM
hardrock21's Avatar
I just installed my Raptor Shift Light and had to set it at 4-cylinder like he said, that's just how they are set up for the LS1.
Old Nov 12, 2005 | 10:02 PM
ninobrn99's Avatar
its supposed to be set to 4.
Old Nov 12, 2005 | 11:47 PM
WS6nJAX's Avatar
Restricted User
my bad fellas.....thanks for the help.
