idle histogram..not supported
Old Nov 12, 2005 | 10:31 PM
ninobrn99's Avatar
Default idle histogram..not supported
what does that mean?? i tried to use the idle airflow histogram and its saying that its not supported. so then i tried to log my stit's, ltit's park and gear and my ect's. when the key is turned to on (before turning the engine over, the stits are just a steady line, when the car is on the ltit's p/n come across. what am i doing wrong? Thanks to Bill (foff667) ive got a few things taken care of.
Thanks for taking the time hope i kept you laughing one screw up after another can u guys help me out?? either explain or send me a cfg i can use to log the things i need to do my RAF pls.
Nino
Old Nov 12, 2005 | 10:52 PM
soundengineer's Avatar
go to mt site...down load the speadsheets I have made....
3 different ones on there to play with
Log ECT
Ltit Gear Ac Off
LTIT P/N Ac Off
Stit Idle Adapt
Old Nov 12, 2005 | 11:51 PM
ninobrn99's Avatar
see i tried that, but i dont get any numbers for the stit when the car is running and only ltit's in p/n are scanning. its a stick so how do i get the ltit's in gear??
Old Nov 13, 2005 | 12:11 AM
ninobrn99's Avatar
tried to download it and still getting:
This histogram is not supported with the current loaded parameters.
If this histogram references Tables, it is possible that the vehicle you are connected to does not support these tables. it is also possible that the sensor required for the Table is not found in the loaded parameters.
and goes on and on...basically, it doesnt work
Old Nov 13, 2005 | 01:58 AM
bmfcamaro's Avatar
what are you loading as parameters. you usually use some combo of these depending on histo: dynamic cylinder air, iac position, ltits, stit, idle desired airflow. make sure the dimensions are correct, such as degrees celcius, grams, and so on.
Old Nov 13, 2005 | 07:24 AM
MNR-0's Avatar
You are missing a PID or sensor in the PID table. Nothing wrong with the histogram - it can't log what you don't give it.
