Wide band O2 install location?
I have a X-pipe that bolts to my headers and the cats are mounted to the downstream side of the X-pipe. Can I install the O2 on the downstream side of the X-pipe? Or is there too much turbulance there for acurate readings?
Drill a few small holes and strap the controller down with tie wraps..I found this to be the only good location to mount the controller as all the other locations under the C5 are real low or real hot.
www.dynotunenitrous.com
Cheers
Dan
