Ignition Hot Source on Corvette
Old Nov 14, 2005 | 12:02 AM
alchemistz06's Avatar
Default Ignition Hot Source on Corvette
I was wondering where you guys got your ignition hot 12 volt supply. I was thinking radio, but was wondering if there where any other places. I also searched and found that the orange wire to the left of the kick panel on the passenger side. But i looked and that orange, yellow, and black wire don't seem to be connected to anything.
I was also wondering if the system ground can go to the same place as heater ground or it plugs into the ground on an hptuners EIO connector. What is the difference between system ground and analog ground. I also want to confirm if only two wires from from the lc-1 actually go to the eio connectors, analog out 1 and analog ground.
thanks for your help and input.
Old Nov 14, 2005 | 03:21 AM
Dixit's Avatar
One end of it is not connected to anything, however the other end is connected to the hot 12volt. One is 12V hot all the time, one is ignition source, and other is ground. That is where my headunit is tapped into.
Dixit
