85 mm maf recalibration
You can change your PID's to read lbs/min or g/sec.. that should help.
Under PIDS when you selct MAF and DYNAIR.. right click and you can slect Imperial to use lbs/min.
clean your airfilters first, i've seen it more than enough times to be the culprit.
