at what point do u mess with timing?
I generally dial my VE table in first, then modify part throttle spark if you're getting KR
Then I'll adjust my PE, then I'll adjust my timing... if need be I'll go back and readjust me VE where necessary and then readjust PE as necessary
If VE was a true representation (it could be in some instances, I'm sure others can tell you how it correlates to true VE) then that 26 means that your cylinder is 26% of its capacity.
Your VE value isn't telling the computer how much fuel to add, rather how much air is in the cylinder. The calculations the computer does uses a few inputs, and air mass is one of them. Depending on the air mass it comes up with, it determines via other tables what AFR its supposed to be at and adds the appropriate amount of fuel to reach that. That a very general explanation, I'm sure a lot of other people will sharpshoot it
Since airmass is a product of density * volume, although your volume would stay the same your density would increase.
ill try to convince my wife to come with me friday to the Q. Are you gonna be running or just watching?
Thanks, if I can't grab a set from them I'll let you know.
