OBD1 LT1 - Need Help
Old Nov 17, 2005 | 03:36 PM
wolfsburgfanatic's Avatar
Default OBD1 LT1 - Need Help
I know this is a LS1 site and whatnot, but LT1tech doesn't seem to get much traffic and I need to get this resolved ASAP...
My car (1994 Camaro Z28 M6) has begun throwing a SES light once the car has warmed up. I tried to have it scanned at autozone, but apparently they only do OBD2. I know the dealer is gonna rape me and I'm poor, so how do I go about scanning it myself? I work at a shop and have access to anything I would need, I just don't know what to do. This is my first car without a warrenty, so I'm a bit of a noob as far as this stuff goes. Any help would be appreciated
Old Nov 19, 2005 | 06:45 PM
Bill Bowling's Avatar
Try here:
http://www.mastach.com/index.php?mod..._hardware&l=en
Good luck.
Bill
Old Nov 20, 2005 | 12:19 AM
fast98's Avatar
you can ground the 2 pins on the dlc that are at the top right when you look at it. only if its a true obd1. turn the key on while doing this. if you have electric fans they normally turn on. you have to count the flashes of the ses light. its gunna flash 12 3 times and then whatever code you have 3 times and then 12 again. example. if your code is a 21 it will go like this when you ground it................flash........flash..flash thats 12, again it will do that 3 times. 21 is ...........flash..flash........flash, 3 times. just report back here with your codes. o and try and find a paperclip for this it works best
Old Nov 20, 2005 | 02:40 AM
SILVERZZ28's Avatar
OBd II started in 1996 ! Sound slike a 02 sensor
Old Nov 20, 2005 | 06:00 AM
Ed Wright's Avatar
9-Second Club
That does not work on '94/'95 LT1 PCMs. Takes a scan tool to retrieve codes. Those are still OBD1.
Old Nov 20, 2005 | 04:41 PM
fast98's Avatar
that would make it obd1.5 then. good info
Old Nov 23, 2005 | 01:34 AM
infinitebird's Avatar
If you have a laptop just get a cable (best serial one is at akmcables.com, best usb option is moates.net) and use datamaster or freescan to check it.
Old Nov 23, 2005 | 03:48 AM
figured it out, airpump died. Thanks guys
