which tables to correct dipping idle on decel?
Old Nov 27, 2005 | 05:27 PM
WS6FirebirdTA00's Avatar
Originally Posted by Ragtop 99
The first 7 cells stock are zero for a 1999. I've reduced the remaining cells for a 90mm FAST TB using the 48% factor. Therefore the next 5 cells are not zero, but about half of stock. Is that reduction causing a problem?
0-28 are zeroed on mine, effective area is not an issue. as long as you set it up correctly and tune the RAF it wont hurt, it helps so the computer knows how much air it actually lets in. everyone swears up and down not to touch this with a stock TB but mine is totally different from stock and is working fine. besides over and underfueling from the o2s on decel, i see absolutely no other issues.
Old Nov 27, 2005 | 05:55 PM
SmokingWS6's Avatar
Originally Posted by WS6FirebirdTA00
car is fine in open loop, it is all due to fueling. messed with the throttle cracker to get the rpms nice comming to a stop. im sure i could decrease the decay to make it last longer but thats patching a problem that is there. the second i turn off closed loop the **** is perfect, no over or undershoot at all. so ill deal wiht it until i have an open loop tune
How healthy are the o2's? good o2's will make or break idle in my experience.
Old Nov 27, 2005 | 08:16 PM
z06ufgrad2002's Avatar
I've got the same problem but, it is much worse witht the a/c on vs off. Idle is pretty solid with a/c off.
Any ideas?
Old Nov 27, 2005 | 08:49 PM
they are brand spanking new denso corvette rears, i think im going back wiht stock ones as these are pieces of ****. actaully take LONGER to heat up, and oscillate much much slower than the stock ones, even with changing the proportional fuel to help out. they are pretty damn accurate though, when they are nice and hot i tune off them and when i put the WB on its pretty much dead on +/- 1%
Old Nov 27, 2005 | 08:50 PM
SmokingWS6's Avatar
From what I've read Denso's don't work. I'd stick with stock on Bosch 13111's.
Old Nov 27, 2005 | 09:04 PM
i talked to quite a few guys with bosch that get insufficent switching codes with them. i think im going to order some OEM o2s when i get money
Old Nov 28, 2005 | 04:20 AM
MNR-0's Avatar
It depends on your IAC counts on decel. Log the IAC counts on decel. to find out whats happening. If they reduce to 0, then you no longer have stepper motor control so everything you do from that point on is useless. At idle, you need anywhere from 20-100IAC counts. On cruise, it could be more than that, maybe upwards of 180IAC counts. Bascially, you ALWAYS want IAC motor control or the car relies purely on the TB position.
Old Nov 30, 2005 | 10:23 AM
well i have messed with about anything you can, i cant really tell if the dip has gotten better in closed loop, i think i have to figure off the rich condition before i can fix it, and that doesnt want to go away with these injectors
Old Dec 1, 2005 | 11:26 AM
jerflash's Avatar
wel i have the same issue in my m6
but mine only happens if i bog it down to below 1000 when in gear and then push the clutch in
but mine does not raise up untill i hit the gas and it stumbles a lil bit
Old Dec 2, 2005 | 07:47 AM
P Mack's Avatar
48% factor!?!?! Holy ****, I must have posted 10 times in that thread that it's only for drive by wire throttle bodies.
I don't know why nobody can figure this out, but an f-body pcm doesn't care how big your throttlebody blade is because it doesn't control the throttlebody angle. It probably is causing a problem, possibly not, but you definately changed it for all the wrong reasons.
Old Dec 2, 2005 | 08:30 AM
Ragtop 99's Avatar
I definitely made a mistake and overkilled it, and I don't mind being bitch slapped when I ignored clear advice, but I'm not seeing it. I see 2 posts in that thread from you relative to the 48%:
How did you calculate 48% again?
Your next post was in respone to the question "also where in efi live is that scaler...I'm under idle and I see IAC area, idle speeds, start up correction, idle airflow, idle airflow parked....etc"
You don't need it since you don't have an electronic throttlebody.
The full thread that I got the 48% from is here:
https://ls1tech.com/forums/pcm-diagnostics-tuning/335186-update-90mm-tb-48-effective-table.html
Maybe there are other threads with it where you posted that. In any case, anyone reading this will not make the same mistake.
Old Dec 2, 2005 | 01:39 PM
  #32
P Mack's Avatar
My bad, i've probably replied to a couple different threads on the subject so i shouldn't expect you to know that. I see now that i only replied once in the original thread. Sorry for the bitchslap
Old Dec 2, 2005 | 07:06 PM
  #33
87Fake's Avatar
I have the same problem, not so much anymore. For me it was the effective area table being off. I tried messing with cracker and follower with little success. I built mine by logging commanded iac airflow and actual maf airflow and tweaked it till both were pretty much identical at all counts.
Now for the most part in a CL maf tune it comes down to idle real nice with ac on or off in cold or hot weather.
The only problem I have is sometimes driving slow with alot of clutch in/out, throttle on/off action it will stumble, and the friggin reverse stumble.
Old Dec 2, 2005 | 07:33 PM
  #34
silverTA2002's Avatar
Originally Posted by MNR-0
Decel. is all follower. Cracker opens the IAC motor on accel. and maintains airflow at cruise. Everything, though, based around the Base Running Airflow table. You always start there - solves 90% of all problems.
If you have zeroed out the first dozen IAC cells in the "IAC vs Effective Area" table then its slewing your follower control, hence dropping right down. Whats recovering for you is the Stall Saver.
I would set the cracker and IAC tables back to stock and work from there.
Decel. can't be all follower. If that were true, then why does my idle level out at the point that I disable "throttle cracker?" Currently, I set it to disable at 9mph and enable at 10.
I've been tuning my idle for a few months now, and still have similar problems to what he's describing. Idle will go down, then back up to 1200, then sit there or around 1000 till I stop.
It changes depending on my RAF numbers. IAC vs. EFFECTIVE is dialed in since the dynamic and actual airflow numbers cross. My IAC counts are 45-50 when warm.
I've been through probably 30 idle tunes so far.
Old Dec 2, 2005 | 09:18 PM
  #35
send me your bin and ill check it out. if your ve is off that will cause issues as well, or slow switching o2s
