97 vette with boost
Old Nov 30, 2005 | 02:49 PM
kindaslo's Avatar
Default 97 vette with boost
I've got hp tuners and have been using it to dial the car in at part throttle n/a. I went to order the 2-3 bar map setup today, to find out that hpt does not support that setup earlier than 99.
I knwo there has to be a solution, and int he edit days you could swap an obd 2 pcm into an obd1 car to get better tuning ability, can this be done with the newer cars? (i.e. 2000 vette pcm in a 97 vette so that I can take advantage of 2-3 bar map setup) or maybe option 2 of just drop a 3bar map in and slowly rework the entire ve table to match while losing resolution (yikes) or blow it through the maf (equally yikes)
Anyone been down this road yet?
Old Dec 1, 2005 | 04:25 PM
kindaslo's Avatar
Nobody has turbo or supercharged a 97 vette?
Old Dec 2, 2005 | 10:20 AM
bmfcamaro's Avatar
you have to swap the harness also. but yes i am pretty sure you can
