For a boosted app., which tuner?
Old Dec 2, 2005 | 07:37 AM
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
Default For a boosted app., which tuner?
Is EFI or HPT better for a boosted app (under 15 PSI) and maybe some NOS?
Not looking to start a war
TIA
Old Dec 2, 2005 | 07:39 AM
Billiumss's Avatar
Either one will work fine. Check out each others forums and also check out the prices for each package to determine which one fits you.
Old Dec 2, 2005 | 07:40 AM
HumpinSS's Avatar
EFILive will be releasing some nitrous specific Custom Operating systems soon this coupled with their boosted OS should do everything you want and more
http://www.efilive.com/forum/viewtopic.php?t=2638
Old Dec 2, 2005 | 07:57 AM
rjw's Avatar
rjw
I guess that I should have stated that I already own HPT.
I need to hook up a wideband and now I probably need to go to a 2 bar MAP, in that I need to flow around 1000 CFM and it seems cheaper to dump the MAF rather than try to find one that flows that much.
So with HPT, I need the enhanced interface and 2 bar SD upgrade.
I would have to learn either software
Old Dec 2, 2005 | 05:05 PM
gameover's Avatar
You also need to buy a 2bar MAP sensor. Email us at support if you have any further questions.
Chris...
Old Dec 2, 2005 | 06:41 PM
frcefed98's Avatar
PN for the 2 bar map sensor so you don't have to look around or search.
GM PN 12580698 39.00 from gm parts direct dot com.
J
Old Dec 3, 2005 | 01:22 PM
rjw's Avatar
rjw
Thanks for the P/N.
I found these in another thread
GM PN# 12223861 3bar MAP
GM PN# 16040609 2bar MAP
GM PN# 16137039 1bar MAP
GM PN# 15305891 - pigtail harness
So which 2 Bar will fit an 01 C5 vette, and is the harness needed?
