Who has used a MAFT wih Pace LS6 MAF?
How do you pulg in the MAFT without frying your MAF? ... I haven't installed it yet, I just can't figure out which way it plugs in... <img src="images/icons/confused.gif" border="0">
Re: Who has used a MAFT wih Pace LS6 MAF?
I was wondering about this combo myself. I know someone was running it, but I don't have the details. <img src="images/icons/confused.gif" border="0">
Moderator
I have the PACE '02 Screenless ZO6 MAF and a MAFT on my motor. The PACE unit comes with an optional wire harness (at extra cost) that enables your IAT to plug into it and you just plug the wires that would normally go to the stock MAF from the PCM into the MAFT and the wires from the MAFT into the PACE wire harness adapter. Very easy!
"All Motor 9 Second club member"
I've got the Pace screened and MAFT. It came with the neccesary wiring adapter harness and it's just a plug-in set up. Just be very careful with the pins when connecting them. Do NOT force them together.The harness allows you to connect the AIT into it and read the Intake air temp through the MAF like the LS6. On mine, the Ltrims were almost ideal but I had to lean out the O2s a little.It's a good piece though.Good luck.
