Autotap Log help . Look at this KR
Old Dec 2, 2001 | 09:38 PM
LS1[CHEVY]'s Avatar
Default Autotap Log help . Look at this KR
I was on the juice this run too.
What are your opinions ?
[ December 03, 2001: Message edited by: LS1[CHEVY] ]</p>
Old Dec 2, 2001 | 09:39 PM
LS1[CHEVY]'s Avatar
Default Re: Autotap Log help . Look at this KR
You gotta cut and paste the addy in a new window <img src="images/icons/frown.gif" border="0"> Geoshitties is killin me <img src="images/icons/rolleyes.gif" border="0">
Old Dec 3, 2001 | 08:38 AM
LS1[CHEVY]'s Avatar
ttt . Could someone give me idea what to look for to eliminate the knock.
Old Dec 3, 2001 | 11:11 AM
Colonel's Avatar
Looks like you started getting a little lean there at the top.
Use some unleaded race gas to verify that your KR is real.
Old Dec 3, 2001 | 11:53 AM
LS1[CHEVY]'s Avatar
I have the n2o commin on a t 3000RPM and shutting off a 5200RPM . It does look like im getting a bit lean at the end of the run. What can I do to fix that? Do you think I should stop spraying until the KR is gone?
Old Dec 3, 2001 | 04:44 PM
Nine Ball's Avatar
LS1Tech Co-Founder
might be a combination of real and false knock. Notice how the KR jumps up right after you shift into that last gear? Usually a sign that false knock exists. Any exhaust banging during a hard shift?
Personally, I wouldn't spray it until you know what is causing the problem. Run some 100+ octane unleaded and see if you still have KR.
Tony
Old Dec 3, 2001 | 06:10 PM
LS1[CHEVY]'s Avatar
I cant hear any banging . The car does rumble/vibrate alot with the 3in cutout open .
How much 100 octain do I need to put in the tank to be sure?
Old Dec 3, 2001 | 06:11 PM
LS1[CHEVY]'s Avatar
Also , should I remove the heat sheild above the muffler? Im also doing the vertical PVC mod to eliminate oil getting in the TB .. Someone said this could cause a less than efficient burn and cause knock. O yea and Im going to to a top end clean . What do you reccomend for that?
Old Dec 4, 2001 | 08:50 AM
LS1[CHEVY]'s Avatar
ttt
