ls1 edit ????'s maps etc.
If I buy LS1 edit when available for my 99 ss can I have someone like Thunder racing make a few MAPS on the dyno...ie one for 93 octane, 104 and one for N2O, and then me(as I learn)make my changes?
I have used a power commander for a motorcycle that is easy to use, but I am not sure about LS1 edit, The bike thing only consists of a chart with rpm and %throttle and you go in and add subtract fuel/timing for each rpm. Is this similar to LS1 edit?
I know Thunder can program with their "un-locked" version...but can you save different maps etc. for different applications?
As far as adjustments, it is more complex than your motorcycle tuner. Although there are quite a few tables to work with, you can leave 90% of them untouched if you don't feel safe about what you are doing untill you learn more! Thing is its all up to you on what you want to do with the tools that are available.
Ryan
