Custom tuning or Ls1 Edit what is the difference
Old Feb 10, 2002 | 09:33 PM
allblackSS's Avatar
Default Custom tuning or Ls1 Edit what is the difference
I have posted on here alot to find out about this and i cant get any respones i wast to know about the new thing the ls1 edit or custom tuning i know that i need one of them btu i dont know which will be more worth my money i have heads cam headers and ls6 intake i am probably going to get me a different shortblock im notcar stupid but not a geniuse either which one these will i be able to do more with or get the most power out of i really would like to know the car is a 98 model. i would really appreciate any help that you could give me
thanks bubba
Old Feb 11, 2002 | 11:21 PM
Godspeed's Avatar
Default Re: Custom tuning or Ls1 Edit what is the difference
In order to effectively tune your car with LS1 Edit you will need to spend some time on a dyno with widebands and preferably with a Tech 2 or Autotap at the least. If you can't do this yourself or don't have access to a shop that could do it, I would recommend you get a custom PCM done. For your combo - heads/cam/headers/intake many of the tuners have custom PCM's down that are really good, which you may not be able to exceed with LS1 Edit. However if you plan to make changes and want the flexibility of LS1 Edit to continue to tune and make adjustments would be nice. I'm sure if you stick around here long enough you'll figure out enough so that you can use LS1 Edit. Good luck. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
-Jeremy
<img src="gr_grin.gif" border="0">
[ February 12, 2002: Message edited by: Godspeed ]</p>
Old Feb 12, 2002 | 04:45 PM
Mr Cowl Hood's Avatar
Hey Jeremy,
Are you the Jeremy I met in Dallas a month ago? I tuned Devin's car at Speedworks when I was down there.
Bubba,
If you think you can learn a little tuning, there are things you can change in LS1 edit that will make some mild improvements, but if you watch what you're doing it can be a safe road to learning how to tune. We all started somewhere, right. If you want a custom tune, you could do that first and then get LS1 edit later.
I can say personally (I have the 97-00 pkg) that it is a very nice gui interface and relatively bug free. I am a Beta tester as well as several others. We have all found a few bugs, but Ken and Dave really jump in on what we're ask for.
I hope this helps. <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
[ February 12, 2002: Message edited by: Mr Cowl Hood ]</p>
