Team ZR-1 - EASE ?
I got scan with del.TRQ. The field says it's newton meters, but looking at the numbers, that can't be. MAx dl. torque is 318, if I convert that from newton meters that's only 234.
Could this value be ft lbs already?
Also.... 1st I've seen minus # in advance. Should I be adding some misfire parameters?
I'm running this in XP, maybe its just that?
You need to send me a private e-mail and I can tell you where on my website there is a fix for nm - ft/lb and bogus deltq numbers.
I worked with Ease and G.M and there is a fix that can be done on the Ease to correct the G.M math problem.
I tried to get autotap to fix that and they told me there was no bug, so let em continue to put of invalid numbers.
If you see negative deltq numbers tat is either from lifting off of TPS or torque management has kicked in.
If your in cell 21 then it should be negative, if in 0-19 cells and you see negative numbers thats a T.M issue.
