? on LS1 Edit
Old Mar 1, 2002 | 01:15 AM
Judd's Avatar
Default ? on LS1 Edit
If I want to change the speedo cal., change fan turn on, get rid of the rear 02s, and get rid of the EGR check - would I still need AutoTap? I am stock and most likely don't need to do alot of tuneing and can't afford both right now. Since custom tuneing and LS1 Edit run about the same $, could I just use LS1 Edit?
Old Mar 1, 2002 | 06:15 AM
Black LS1 T/A's Avatar
Moderator
Default Re: ? on LS1 Edit
Yeah, you can do that with LS1-Edit.
Old Mar 1, 2002 | 08:31 AM
pontiaddict's Avatar
You wouldnt need atap to do those things ,but eventually you would want it for reading your tunes.
Old Mar 1, 2002 | 09:26 AM
Doc99SS's Avatar
How do you get "rid of the rear O2s" with LS1-Edit?
I have LS1-Edit. Where do I go in the many tables to do the above?
Old Mar 1, 2002 | 11:57 AM
Ryan K's Avatar
Pathological Modifier
Doc99SS
The way you "get rid of" the rear O2 sensors is to delete any codes that they would set. I don't have my books with me right now, but I will get you all the numbers this evening.
Ryan K. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Mar 2, 2002 | 01:50 AM
Judd's Avatar
Hey y'all thanks for the info. Modding is expensive! Little bit at a time. <img src="gr_sad.gif" border="0"> <img src="gr_grin.gif" border="0">
