camaro cluster ?'s
Old 12-13-2005, 07:41 PM
flynlow3's Avatar
Default camaro cluster ?'s
I have had problems with my tachometer reading correctly. I noticed it reading high at idle and a bit slow to react when i give it gas. I am currently looking at a used cluster on ebay. It has a few less miles. Will this maybe fix my tach problem? or is it more than likely something in the pcm? Also is there anything i have to look for other than year? Its a manual tranny does that matter?
Thanks
Jeff
Old 12-13-2005, 08:48 PM
rtr2001ss's Avatar
It shouldn't matter year or auto/manual wise, as long as it's 98-02 maybe even the 97's will work too, same design. I bought a Trans Am cluster for the plastic bezel piece, put in the cluster for the hell of it. Everything worked like it was supposed to. Of course I didn't keep the TA cluster in, just the bezel overlay.
Old 12-14-2005, 01:54 AM
flynlow3's Avatar
Will the mileage change according to how many are on the new cluster or will that info remain in the computer?
Old 12-14-2005, 05:29 AM
itchygomey98's Avatar
If you have a 98, you need a 98 cluster. The other years aren't pinned (wired) the same. The odometer will show whatever the cluster has in it. So yes - your mileage will change.
Old 12-14-2005, 06:19 AM
rtr2001ss's Avatar
Didn't know about the pin change. Follow his advice on that.
Old 12-16-2005, 05:14 PM
flynlow3's Avatar
I bought a 99 cluster which is the same yr as my car. It has about the same mileage which i was worried about. Thanks for the advice though.
Old 12-16-2005, 06:08 PM
2001NBMZ28's Avatar
Don't know about your tach not reading correct/mine has always seemed slow to react. When I saw used '99 cluster + ebay just wanted to be sure you knew about the '99 cluster TSB - it's in this post and lists old/new cluster PN's too www.ls1tech.com/forums/showthread.php?t=359115 Not saying you'll have a problem, just wanted to make sure you knew about it.
