Help with electrical problems
When splicing in new wires (an additional 7 ft in length) I used 18 gauge for all of those wires which include passenger ABS, oil pan, engine fuel, purple starter wire, passenger Front 02.
What I need to know is after watching the voltage on that 02 it is up and down with the driver's side for about 5 minutes. At which point it slowly starts to decrease voltage down to .1, I have ruled out the sensor and the computer. So the filament inside is burning up right? I re-routed the wire harness between the engine and the
headers where it is heat shielded next to the positive starter wire. I thought well maybe that I crossed a wire when crimping. However, if I had the sensor would read .45 all the time, like it was unconnected.
Any comments would be appreciated. Since this looks like an area that most mechanics know little about where can I get a good starter book on Automotive electical wiring, diagrams, and tools needed?
If the 02 stops moving it could be messed up. Did you run really rich for a while?
I am on my 3rd set of front 02's.
Basically after the dyno tune I got all the SES lights for front and rear 02's. The computer does some strange things when just one 02 out of four goes bad. Last night it tripped the P rear 02 code, 1060 and started missing under load. Now I have had those turned off via the PCM for two months but there it was.
Went through new 02's wiring and a new PCM can't figure it out. My knowledge on Wiring is very weak, but here is my theory. That the length or the gauge of the wire replaced is destroying each new sensor. If I had the wires crossed when I lengthened them, the 02 wouldn't read anything but the standard .44 and .45, like when you just disconnect the 02 at the plug. Instead the sensor works for 5 or 10 minutes before starting to fall way off and the Sterms and Lterms start spiking.
What would cause the 02 to read right and then after it is heated up start dropping off in voltage, creating a rich condition? Does something happen to the sensor after it is warmed up, like the circuit is completed? A ground, a crossed wire, this has been going on since January now.
I think I need monitor the voltage through the wires near the computer and at the 02 via Atap, after I find out what each wire should show.
[ March 06, 2002: Message edited by: Raytheon ]</p>
