"Big cam idle"
Old Mar 10, 2002 | 03:17 AM
sross's Avatar
Default "Big cam idle"
Does anyone have any input into cleaning up "big cam" idle? Idle speed is obvious but what about spark and fuel? I know "bigger" cams can idle well. There's got to be a better way than raising the idle speed. ****, I could do that with a carb. What about with EFI? More advance should smooth it out, right? What about A/F mixture? Lean towards the rich side?? Even if you're not sure, let's hear you're experiences...
Old Mar 10, 2002 | 06:17 AM
Freak's Avatar
Default Re: "Big cam idle"
I would lean toward the lean side at idle, if you think about it, installing a big cam usualy requires a TB plate drilling, which would effectively lean the mix at idle...
I would try using Atap to check the MAP readings, and try to get the highest vacume you can.
probalby advance the spark a couple of degrees, although Im not sure wehre idle advance sits...
Old Mar 10, 2002 | 07:21 PM
Terry Burger's Avatar
It depends on the cam, but lean the idle out, and pick a decent idle speed like 900rpm.
Old Mar 10, 2002 | 07:36 PM
Black LS1 T/A's Avatar
Moderator
Terry "Don't hate me because I'm beautiful" Burger <img src="gr_grin.gif" border="0"> <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
I LIKE it!
