How do I delete traction control & other functions
Old Mar 10, 2002 | 09:19 PM
99LS1_TA's Avatar
Default How do I delete traction control & other functions
I have already purchased ls1 edit. I have an ls1 that I am doing an engine swap with and would like to delete the traction control. How can I do this with ls1 edit?
I would also like to delete other items such as egr, air pump, rear o2 sensors, and skip shift. Do I just unplug these items then toggle off any codes that may be set?
Any help would be greatly appreciated.
Old Mar 11, 2002 | 06:12 PM
chasgiv3's Avatar
Default Re: How do I delete traction control & other functions
Toggling off the codes is all you really have to do.
The traction control I'm not sure about. I know you can manipulate it but I haven't seen it.
Old Mar 13, 2002 | 07:16 PM
99LS1_TA's Avatar
Thanks for the info. Now I just need to figure out how to delete the traction control.
Old Mar 13, 2002 | 07:47 PM
99 WS6's Avatar
I don't think the traction control will matter. The ABS computer is the one that takes care of the traction control. It then sends requests to the PCM to reduce throttle/timing. But, I could be wrong.
Old Mar 15, 2002 | 01:34 PM
WFO_SS's Avatar
99 WS6 is right. it's controlled by the abs module w/ the exception of timing control & throttle control.
