LS1 Edit Injector Scaling
Thanks Jeremy,
Scott
Regarding the injector offset, I belive the SVO injectors are slower than the GM injectors. The injector offset is expressed in (ms) in the PCM and is the time delay for opening the injector. I would think that you would need to decrease the injector offset for the SVO's. I'll see if I can come up with a better answer for you.
<small>[ March 14, 2002, 07:37 AM: Message edited by: Godspeed ]</small>
Thanks Jeremy,
Scott </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks, I added them.
-Jeremy
<small>[ March 13, 2002, 04:34 PM: Message edited by: Godspeed ]</small>
-Jeremy
Percent (%) is expressed as a fraction of 1.00, so 1.385 would be 138.50%. Multipling by 101.385% would only increase the values by 1.385% - off by two decimal places. Multiply all the cells in the table by the correction factors I have listed, not as a percentage.
Some of the larger injectors actually flow twice as much as the stock injectors, giving us a large correction factor of over 200%. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Jeremy
<small>[ March 14, 2002, 07:38 AM: Message edited by: Godspeed ]</small>
<strong>My numbers for 30# SVO were a little off I think. Any idea how to figure out what the injector offset for 30# SVO's should be?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't think the SVO injectors are rated at 39 psi. I heard that about 5 years ago (and several times since) but I think they're rated at the "standard" 43.5 psi. Try using 1.33 for your correction factor. That should get you better numbers. At least it did for me.
Please give us an update.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Duke:
<strong>
Now let me get this straight. Actually, when you say multiply the table by the correction factor: if the correction factor is 1.385, them you multiply by 101.385%. Is this correcto mumo?
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Close. You want to multiply the entire table by 138.5%.
<small>[ March 13, 2002, 05:32 PM: Message edited by: sross ]</small>
I may just list both 39psi and 43.5psi in the chart until I can confirm for certain which is true. Hell, I may just have a set of SVO's flowed, so I will know for sure.
-Jeremy
<small>[ March 14, 2002, 07:29 AM: Message edited by: Godspeed ]</small>
-Jeremy
<small>[ March 14, 2002, 07:40 AM: Message edited by: Godspeed ]</small>
John,
According to Harlan (in an injector thread on LS1Tech.com), your
injectors are Delphi 37lb at 3.5 bar which makes them 39.55077lb injectors
at 58PSI (4 Bar) NOT 38lb injectors... So....
According to my math, you would use the following table for LS1Edit for your
injectors. Since they are a Delphi Injectors thus Multitec 2's, they
probably have the same or similar flow curve as our stockers so we can use
the stock injector math as a reference. Have Brian at BV try this table
if he hasn't already calculated it on his own, so far the numbers I've been
able to generate when given accurate info about the injectors have been
pretty accurate.
KPA 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
New Injector Flow using Reference Curve 4.96 4.98 5.02 5.05 5.08 5.10 5.13
5.16 5.19 5.21 5.24 5.27 5.30 5.32 5.34 5.37 5.39
The numbers starting with 4.96 for 0 Kpa get put into LS1 edit in the Fuel
Injector table.
John@PACE
<small>[ March 14, 2002, 02:52 PM: Message edited by: Pro Stock John ]</small>
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks, I'll update the info. Perhaps I should just do all the calculations for the table as well. Hmmm...
-Jeremy
HTML Version
Excel Version
Acrobat Version
-Jeremy
<small>[ March 13, 2002, 09:37 PM: Message edited by: Godspeed ]</small>
If you are able to adjust your fuel pressure and you are running SVO injectors, couldn't you just lower the FP to 43psi and then just do the math for the difference?
That is, I have SVO 42lb injectors, and my FP is set to 43psi, so:
42/28.6 = 1.43 (CF)
I can just use this CF throughout my tables if I set my FP at 43, right?
To further confuse the issue, I want to run my FP at 50psi because the TNT wet kit is jetter for 50 psi, so I do a new flow rate that looks like:
new rate = sqrt(new psi/old psi) x old rate
= sqrt(50/43.5) x 42
= 1.072112 x 42
new flow rate @ 50psi = 45.03
the 45.03/28.6 = 1.57cf
So the CF for 42lb SVO injectors at 50psi would be 1.57? I think this is right?
OBTW...the table is great! I printed it for my LS1 Edit Binder. I am compiling everything I can, so when questions come up, I will hopefully have the answers <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ March 14, 2002, 11:17 AM: Message edited by: Reckless ]</small>
If you have a 48 psi of rail pressure and 10psi of vacuum you have a 58psi delta across the injector - so you need to use the manifold vacuum + the rail pressure in your correction factor -
and since the table is scaled vs. manifold vacuum the correction will not be constant.
http://www.speeddemonmotorsports.com...ectorscale.xls
that is a quick spreadsheet I typed up to automate the conversion
I think there may be a bug in LS1 Edit - in the scaling of the MAP sensor. It shows flow rate INCREASING as MAP goes up - but the higher the MAP the lower the manifold vacuum (since it measures absolute pressure). Injector flow should increase directly with manifold vacuum, so it should DECREASE with MAP value.
The spreadsheet works currently with the values as stored, and will be correct (just about) if the scaling is actually 80-0kpa. If it is 100-20kpa like I suspect or something else then it may need to be tweaked.
Then at 50psi, your at 47.55564lbs
5.99201 g/sec
98 injector table shows 3.64g/sec which makes the 98 injectors more like 28.8 almost 28.9lb.
You'll have to fine tune of course, but I would do the math on g/sec as LS1Edit uses it. Doing the percentage on lbs would yield 6.01 g/sec
John
