Anyone else get code PO480-fuel tank pressure circuit?
Unless the codes changed from 2000 - 2001????
Anyway, the Helms lists the 480 code as the fan circuit.
I use the DOS ATAP, if it makes any difference?
I've never had the code cause the MIL to come on,not sure under what conditions the code sets but is probably when I have the fans running and restart the car,may also happen under other conditions. I've had both 480 & 481 codes. Interestingly, these are the only codes my car has ever pulled that I've seen except when I've left the MAF and IAT unplugged.
My switch is wired for both hi/low fans and I'm tapped into the wiring harness that goes to the pcm on the pass fenderwell.(blue and green wires to fan relays)
