2 step idea using LS1edit?
Any ideas?
<small>[ March 21, 2002, 05:54 AM: Message edited by: Fireball ]</small>
But that is one creative idea, hope it pans out.
It didn't really answer the question directly on rev limiter. But once the inop code (DTC 500, 503, or 503) is set the MIL comes on and stays on for 3 key cycles. Sounds like it won't work <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> anyone else have more detailed knowledge?
I think the fact that the inop code is not set for 100 secs (plus the conditions must be met) might be the downfall of the idea. Suppose you have that much time prior to staging to set the code though.
if not what i was thinking was you could keep all of your idle speeds the same except when the a/c is off and the car is in drive.
You would change this one to whatever you want to stall at off the line. just turn the a/c off when your at the line, then turn it on when your finished so it doesnt idle so high.
i think i will try this for me since i cant launch at 1200 anyways with street tires on a truck without getting a 29.6 sec 60ft lol.
Bryan
But that's just me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
