req-ls1edit file from m6
Old Mar 21, 2002 | 07:11 AM
cablebandit's Avatar
Default req-ls1edit file from m6
Can someone send me a ls1edit file from their car that has 42# injectors AND has the ltrims between 0 and -10% I dont care about the timing curve of maf tables. I want to see what my car does with ltrims that are not locked. You'd have to READ from the pcm after you have the ltrims close. Actually a 38# injector file would probably close. I have a 2000m6 T/A so it would need to be something comparable.
Old Mar 22, 2002 | 11:52 PM
ChrisB's Avatar
Default Re: req-ls1edit file from m6
DO NOT LOAD THE FILE!!!!!
LS1 Edit only updates the data portions of your program, not the entire code. If you use someone else's program then you will be updateing random portions of code. If you get lucky it will be the same, but tehre is no way for you to tell.
Additionally, if Ed's change isn't to a table, but to the code itself updating the LS1 Edit data tables will moke no difference.
you can also easily kill/fry your pcm doing this.
You can only upload a version of the file you downloaded from your pcm.
