quick autotap question
Old Mar 21, 2002 | 04:59 PM
Sky042's Avatar
Default quick autotap question
What numbers should I be looking at on my O2B1S1 and O2B2S1 trims to see if i'm rich vs. lean. Also What field under transmission will show me the transmission pressure.
--Sky
Old Mar 21, 2002 | 05:47 PM
FastAl's Avatar
Default Re: quick autotap question
For the O2's at WOT you want them somewhere around .89 or so. If they are reading higher you are rich and lower lean. I would highly suggest you get the ltft spreadsheet and dos autotap config file.
Can't help with the tranny since I have a manual right now.
Old Mar 22, 2002 | 11:39 PM
ChrisB's Avatar
As long as yoru stock o2's are between 820-980 or so you are probably fine. It's impossible to just claim a target voltage - and a few mV variation from that voltage can be a large difference. I would tune your car so it feels good in that range, then put it on a dyno with a wideband.
