Tuning for cam?
Old Mar 31, 2002 | 08:45 PM
Freak's Avatar
Default Tuning for cam?
I am starting on idle tuing for my cam, have the TB drilled out slightly, but not where it should be, gonna try to tune as far as I can them see if it still needs to be drilled more.
I have the idle speed at stock, and Ill probalby keep it there (M6) as it idles pretty good there when warm, Cold Idle has been upped a tad.
Plan on advancing the timing at idle about 1-2 degrees and see how it works...
Was gonna try to lean it out at idle, but I dont think I can (because its in closed loop)
does this sound good to those who have done tuning with a cam?
once I get the idle down Ill start tuning for normal driving, then on to WOT... I'm sure Ill have WAY morre questions then. Baby steps...
Thanks
Troy
Old Apr 2, 2002 | 12:52 AM
Ragtop 99's Avatar
Default Re: Tuning for cam?
you can also turn the idle set screw a bit to get more air if your IAC count is high. it is eaiser to fix then drilling too large a hole. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
