'lil help with edit problem please ...long
Old Apr 1, 2002 | 08:59 PM
Kevyn's Avatar
Default 'lil help with edit problem please ...long
First off, I wanted to say hi since I'm a relatively new guy to this site. I have been reading a lot, but not posting much. I think this is a great site.
I have a 98 M6 Z28.
A couple friends (with previous ls1 edit experience) and I reprogrammed my PCM tonite. Things didn't go very well. I'm hoping for a little assistance determining what went wrong and if I toasted my PCM.
We read, then edited my program. We only changed parameters for CAGS, fans and speed limiter since my car is basically stock. (free ram air and a cat back)
We did a read, then flashed the PCM. After the programming, I tried to start the car and the battery was weak. It cranked over a couple times and didn't start, then failed to crank any more.
I had a weak battery and didn't realize it before hand.
We replaced the battery with a new one and it wouldn't start. We reverted back to the original program, same thing.
We plugged in an autotap and got a code of P0601 PCM/VCM Memory. We figured this was not a good sign <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I suspect I'll be buying a PCM but figured I would ask before doing so.
Any words of wisdom would be appreciated.
Thanks
Old Apr 1, 2002 | 09:32 PM
Tim98Z28's Avatar
Default Re: 'lil help with edit problem please ...long
That sucks man! It sounds like the data in your PCM is corrupted due to low power during the flash. Ken can probably help you out, but you will need to send your PCM to him to get it fixed. I hope everything works out ok.
Old Apr 2, 2002 | 08:37 AM
Sparky's Avatar
This a problem we need to pay more attention to! (I know of a couple of guys with dead batteries during HPP loads, same thing!)
My stock battery is approaching 3 years old. I was looking at a light weight replacement but I think I'm going to go the other way and get higher power unit. I don't want to have to worry about problems doing loads at the track, running fans a little in the staging lanes, etc.
Old Apr 2, 2002 | 04:59 PM
C5 YA's Avatar
If you are in a garage and doing this, why not use a battery tender to make sure your battery doesn't die. It wouldn't hurt and save you from purchasing a new PCM. By the way, how much is it for a PCM for a C5.
Old Apr 2, 2002 | 05:36 PM
ToplessTexan's Avatar
Good suggestion. Everything on hard lines <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> The thing I am most worried about now is the OS crashing.
I think I've seen used C5 PCMs going for $200-250. Dont know about new ones. The 97-98 may be a little more since there are fewer of them.
<small>[ April 02, 2002, 05:37 PM: Message edited by: ToplessTexan ]</small>
Old Apr 2, 2002 | 07:09 PM
Kevyn's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by C5 YA:
<strong>If you are in a garage and doing this, why not use a battery tender to make sure your battery doesn't die. It wouldn't hurt and save you from purchasing a new PCM. By the way, how much is it for a PCM for a C5.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">One of the first warnings in the instructions...
"do not leave a charger attached while programming, and do not attempt any other work around the battery"
<small>[ April 02, 2002, 07:09 PM: Message edited by: Kevyn ]</small>
Old Apr 2, 2002 | 09:22 PM
caddyman's Avatar
install a battery charger on low or medium if volts drop below 12 it will lock computor up and you need new one or send out for repair.
you can try this some times it works i have done it at work a few times, also i have never locked up a computor with the charger on the battery.
try disonnecting positive cable from battery and short the cable across the negative cable at the battery some times this unlocks the computor.
Old Apr 2, 2002 | 09:24 PM
caddyman's Avatar
i know a new one my cost for a 96 f car at the dealer is about 170.00 for a new pcm
 Michael S. Palmer
Old Apr 2, 2002 | 11:11 PM
98TAauto's Avatar
i just hook the charger to mine and leave it on low... i cant afford a battery dieing on me while prgraming.. if its on low it cant hurt anything...
i know it says not to leave one connected, but we have been doing this for years when working on equipment with no probs yet
