ls1 edit and top speed??
Old Apr 2, 2002 | 10:47 AM
1dirtyZ's Avatar
Default ls1 edit and top speed??
can ls1 edit modify/ raise your top speed limiter?? if so , how can i do it???
Old Apr 2, 2002 | 01:42 PM
C5 YA's Avatar
Default Re: ls1 edit and top speed??
There is no TOP speed limiter on the C5.
I think you are asking for the rev limiter for each gear. If that is the case see page 29 in the user manual.
The Limiters Tab is dedicated to controlling the Rev Limiters, and the idle speed of the engine.
Within the Test Parameters Tab, you may edit the following functions:
· Idle Speed
· Limiters
· Rev Limit by Gear
· Rev Limiter by Temp
· Rev Limiter Delay
The Idle Speed Table allows you to enter information in RPMs. The first axis is in degrees Fahrenheit. The second axis is what gear you are in and whether the AC is on or not.
Figure 16: Limiters Tab Window
Old Apr 2, 2002 | 02:07 PM
1dirtyZ's Avatar
thanks, but i meant for a camaro. i think stock cuts off at 167 mph.
what is a revlimiter delay?? why would you want it to delay the revlimiter??
Old Apr 2, 2002 | 05:06 PM
C5 YA's Avatar
revlimiter delay:
Is a time delay before switching from the Temp table to the Gear table. The delay is based on the Temperature at startup.
Old Apr 2, 2002 | 05:09 PM
C5 YA's Avatar
This is what you are probably looking for.
6.2 Speed Limiters Tab
The Speed Limiters Tab is dedicated to MPH at which you hit the hard limit and it turns off the fuel.
Within the Speed Limiters Tab, you may edit speed limit, electronic throttle, and hysteresis.
Figure 19: Speed Limiter Window
Old Apr 2, 2002 | 11:03 PM
1dirtyZ's Avatar
thanks again, what is hysteresis <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 2, 2002 | 11:19 PM
98TAauto's Avatar
i dont see the point in messing with the speed limiter since its at 160ish.. i only see 112-120 on the 1/4th so im good to go.. but on a side note i do have my speed limiter set at 255 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
like i could ever hit 167 though <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 3, 2002 | 12:41 AM
1dirtyZ's Avatar
i'm planning ahead, the car will go to the persian gulf ( saudi arabia) eventually, and it's open season when it comes to speed limits there. (it's ok to speed as long as you don't get caught) <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
