Throttle Position error.. Low voltage????
Old Apr 2, 2002 | 08:16 AM
AJH LS1 Z28's Avatar
Default Throttle Position error.. Low voltage????
Throttle Position error.. Low voltage???? Anyone know what this means.. I keep on getting this SES code...
Old Apr 2, 2002 | 08:48 AM
Sparky's Avatar
Default Re: Throttle Position error.. Low voltage????
Is it a P0122 code? If so, the PCM is seeing TPS voltage below .2V for more than 10 seconds.
Could be a bad sensor, wiring or connection problem.
Old Apr 2, 2002 | 08:51 AM
well in that case.. Would the sensor be on the throttle body or somewhere else...??
Old Apr 2, 2002 | 09:00 AM
Nine Ball's Avatar
LS1Tech Co-Founder
The TPS sensor is stuck on the side of the T-body and sits on the end of the shaft that rotates the blade.
Tony
