LS1 Edit ?
Old Apr 2, 2002 | 06:46 PM
99 WS6's Avatar
Default LS1 Edit ?
I am thinking about getting LS1 Edit but I need to know a few things - Can you fill in the MAF tables for higher airflow readings? I will need to tune for a F/I setup and don't know if I would be better off just getting a custom tune done instead.
Thanks
Old Apr 2, 2002 | 09:42 PM
Doc99SShome's Avatar
Default Re: LS1 Edit ?
Yes, you can alter the MAFtable values either with higher or lower values. You can also make changes to part of the table.
Old Apr 2, 2002 | 11:13 PM
98TAauto's Avatar
you can richen or lean your car right out with LS1 edit.. its a dream come true <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 3, 2002 | 02:13 AM
ChrisB's Avatar
You will be limited to 512 g/sec I believe - this is the largest value the MAF transfer table can hold because of the byte size and the way it represents the data.
You are also limited to 12000hz sampling input frequency from the MAF.
Once you hit either of those limits you will need to program "around" them. This is what people have been doing for ages on LTx based vehicles. Basically you will add the extra fuel you need through the PE vs RPM table.
Chris
Old Apr 3, 2002 | 04:42 PM
99 WS6's Avatar
Thanks for the help. I guess I can order LS1edit now.
