WTF - Deleted TM w/ Edit and still get .......
Old Apr 17, 2002 | 09:13 PM
parish8's Avatar
single digit dreamer
Default Re: WTF - Deleted TM w/ Edit and still get .......
am i understanding this?? i have been waiting to buy ls1 edit until i know that the stupid TM can be removed or at least reduced. it sounds like you have figured it out. my truck falls on it's face so hard between shifts i come out of the seat!!
Old Apr 18, 2002 | 09:17 AM
ONYXSS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris99WS6PWTMET:
<strong>SJH,
So I guess the real question in this topic is:
Is the Spark Retard Limit table ONLY for controlling retard during the shifts, or does it serve multiple purposes?
Things that make you go Hmmmm??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Anybody able to confirm this yet? Very imformative thread.
Old Apr 18, 2002 | 10:40 AM
Sparky's Avatar
ttt!
Old Apr 21, 2002 | 06:37 PM
parish8's Avatar
ttt someone has to know this, this one feature alone would almost make ls1edit worth the money.
Old Apr 24, 2002 | 08:28 PM
VT2 EXEC LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>SJH: Thanks for putting it in blunt terms for us; our Aussie mate tried to tell us that, but it didn't sink through. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I think I'm going to try either +10 or +15 above 5600 rpms and leave it alone below that. That way at WOT or near WOT I'll have more power, but no extra wear at lesser part throttle speeds.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks dude. I've had my A4 rebuilt and have matched by retard limit values close to the maximum timing the engine sees at WOT. This makes for positive gearshifts and no loss of power.
Old May 1, 2002 | 09:24 PM
msce2b-dustin's Avatar
I tested mine out tonight. I got rid of tm in every listed area of ls1edit as well as changing the value of the spark retard limit tables.
My last atap data shows me dropping to -14 on 1-2 shift and -10 on 2-3 shift.
Tonight with the above ls1edit changes there was no noticable drop in timimg on the shifts. I didn't have the atap interval set as fast as I would have liked but it appeared to hold 20+ degrees on all shifts.
Old May 1, 2002 | 10:15 PM
mmiller's Avatar
Texas Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by msce2b-dustin:
<strong>I tested mine out tonight. I got rid of tm in every listed area of ls1edit as well as changing the value of the spark retard limit tables.
Tonight with the above ls1edit changes there was no noticable drop in timimg on the shifts. I didn't have the atap interval set as fast as I would have liked but it appeared to hold 20+ degrees on all shifts.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What exactly did you do to remove all of the torque management?
Old May 1, 2002 | 10:29 PM
Chris99WS6PWTMET's Avatar
So you set your spark retard limit table to 20 degrees? If not, then I can promise you that you are dropping down to whatever that limit is set at. ATAP probably just isnt catching it.
Well since this is back at the top I'll ask again:
Is the spark retard limit table ONLY for TM?
Old May 1, 2002 | 10:34 PM
Ok...heres what I did. I don't know if all things compined eliminated it or if one if jsut one of them did but whatever it was it seems to have worked.
Under transmission
a4 shift firmness - torque reduction - set all values to 0
Under Engine
Ignition - Torque Reduction - set all values to 0
Ignition - Spark Retard Limit - set all values to 20
Thats all I did. Like I said...I didn't try doing each one of the above by themselves so I don't know if there is one magic field but the combo listed does work.
I was somewhat concerned intially about seting the retard limit to a number so much differnt than factory (it was -10 all the way across on stock tuning) but I monitored everything and seen know adverse effects.
I will be at the track Friday night and hope to have more data backing this up.
Car - 98 ta, ytp4400 , 3.73, slp lt/orp, bolt ons, weight reeduction, et streets.
Old May 1, 2002 | 10:43 PM
<strong>So you set your spark retard limit table to 20 degrees? If not, then I can promise you that you are dropping down to whatever that limit is set at. ATAP probably just isnt catching it.
Is the spark retard limit table ONLY for TM?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes...set all tables to 20. Had I had set refresh interval in atap a little faster I'm sure timing would have been very close to 20 on the dot. As it was, out of 3 runs (2 1-2 runs and 1 fisrt through third blast, I got a couple of 23's, and a couple 19.5. I'm sure the 19.5 is the most accurate.
Does anyone see a problem raising this up to around 25, especially on a car such as mine which is very, very seldom driven??
My biggest concern when changing the sprk table was that the kr would not work when needed. However I picked up a tad (1.0 or less for just a couple frames...probably exhaust related) of kr on a couple runs and it seemed everything worked as was supposed to.
One other note......the car felt absolutely awesome. Before I atapped my car last year I actually thought my tranny was screwed cause I thought it was gonna throw me out the front windshield on the shifs.
Now there is absolutely no loss in power on the shifts and feels like it should. I couldn't be with the results of ls1edit so far. I bought it because of a heads/cam install coming up in two weeks but to me its already paid for itself.
<small>[ May 01, 2002, 10:47 PM: Message edited by: msce2b-dustin ]</small>
Old May 2, 2002 | 07:05 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I hear you on that. Lately my 1-2 shifts sound like a manual shift with a quick rev before it picks back up and takes off again. <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> TM.
Old May 31, 2002 | 03:19 PM
  #32
98TAauto's Avatar
TTT, now i see what you were talking about ragtop!! i missed this post <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
setting my spark retard from 4800-6400 to 10, then 20 in the 5600-6000 range
