WTF - Deleted TM w/ Edit and still get .......
In the Trans Cal section I zero'd the TQ reduction table.
In the Eng Cal section I:
1. set max TQ to 600
2. zero'd the TCS retard table (already at zero)
3. zero'd the 2nd TCS retard table
4. zero'd the Abuse Mode Reduction table
Still pulls timing on WOT run shifts. Am I missing a table somewhere? Anyone run into this problem yet? HELP!!!
I will let you know if it is taken off...A4's SUCK ***
I'm getting -10 deg timing on all 1-2 shifts at the track. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
<img src="http://www.holdenls1.com/Temp/efilivev5logfile.jpg" alt="" />
Here is a Excel file of the about log file, the program can make a csv file for you, then you import into Excel and you don't need to edit the file at all, Noticed the -8.5 degrees.
Download Zip file here !
<small>[ April 04, 2002, 03:19 PM: Message edited by: SIKLS1 ]</small>
Ken? Ryan? Brain V? Ed? Team ZR-1?
So when i get LS1Edit, i can look at the same problem with mine about.
<small>[ April 04, 2002, 10:31 PM: Message edited by: SIKLS1 ]</small>
Try adjusting the values in the spark retard limit table. Try 10 degrees, then progressively increase the value and record the WOT timing during shifts. That should fix your problem. However, it will probably reduce the life of your trans. Mine does BIG 1-2 skids now <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<strong>This is normal from the GENLS1, same as on the Holden Commdore here, this a log file showing you 1-2 gear change at -8.5 degrees, this log file was capture via EFILiveV5 excellent program.
Download Zip file here !</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The -8.5 is caused by the -10 programmed in the spark retard limit table.
<strong>negative timing during the shifts.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have had the exact same steps done to my PCM on my 2001 by a third party with loads of experience. I have fuel pulled as well after the 2-3 shift and it holds the rpm's to 4500 until I pedal it, we just can't figure this one out.
There has to be some magical cure for this. I know Ed Wright and Mike Morgan PCM's aren't doing this.
Stop messing with the TM tables.
You can set your shift timing anywhere you want in this table.
stock is -10. I set mine at 18 and get 18 degrees on each shift. Actually for some reason A-tap shows up 1/2 degree less than you program in so I now see 17.5.
The table should be re-labled IMO to avoid this confusion as it seems that is all it does is to control the shift timing.
Shift speed table, IMO may be tied into this and could affect how long this table is activated.
I am not positive though.
<small>[ April 16, 2002, 03:55 PM: Message edited by: SJH ]</small>
I think I'm going to try either +10 or +15 above 5600 rpms and leave it alone below that. That way at WOT or near WOT I'll have more power, but no extra wear at lesser part throttle speeds.
I agree with you that setting the timing to a positive value does indeed prevent negative timing during the shifts. I did it at the track and had a marked improvement and it feels damn good. But are you 100% sure that that table is only for timing during shifts? I've been looking for a solid answer on this for a few weeks now and nobody seems to know.
So I guess the real question in this topic is:
Is the Spark Retard Limit table ONLY for controlling retard during the shifts, or does it serve multiple purposes?
Things that make you go Hmmmm??
