Hptuners And Others
That Will Keep All 8 Cly On At All Times, I Hear The System
Disables Cyl If Not Kneeded, Any Comment On This Issue, Not
Sure If It Matters If Its Wide Open , Ha Ha Thanks
In which case surely those 4 are going to get heavily used and wear out faster than the whole engine would if it didnt have DOD?
Maybe just after the 3 year 100,000 warranty?
i don't know what the wear implications are but one would assume that the heat gradients and changed mechanical loads are within design tolerances.
the LS2 pcm has a DOD disable setting that disables DOD completely.
We haven't looked at the 06 Monte so i can't comment on it specifically.
Chris...
