What parameters to AutoTap?
Old Apr 10, 2002 | 11:48 AM
John02SS's Avatar
Default What parameters to AutoTap?
I just got my AutoTap and I'm trying to figure it out. I'm the only one local that has it so you guys are my resource. What fields should I be monitoring and what are "acceptable values" for those fields. Here is what I'm currently monitoring and a few values from my car. Any input in greatly appreciated.
Engine Speed
Vehicle Speed
02 Sensor B1S1- .905 - .910
02 Sensor B2S1- .905 - .910
LTerm Fuel Trim B1- -0.8 to -1.6
LTerm Fule Trim B2- -0.8 to -1.6
Knock Retard - 0 degrees
Ignition Timing Advance- Max 25 (Damn 02' Cam)
Coolant Temp - varies
Intake Air temp - varies
Throttle position angle- 100%
<small>[ April 10, 2002, 08:23 PM: Message edited by: John02SS ]</small>
Old Apr 10, 2002 | 11:53 AM
ChrisB's Avatar
Default Re: What parameters to AutoTap?
I would probably replace the two temperature values with MAF and MAP values, and possibly throw injector PW into the fray also.
It really depends on what you are trying to determine though - it's generally a good idea to keep the number of logged parameters down if at all possible.
Chris
Old Apr 10, 2002 | 07:21 PM
Ragtop 99's Avatar
Your O2's seem a little rich, but our O2 sensors aren't the most accurate.
Could be the GMS is making you rich. LTRIMs look good and no KR is good too.
Old Apr 10, 2002 | 08:21 PM
John02SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>Your O2's seem a little rich, but our O2 sensors aren't the most accurate.
Could be the GMS is making you rich. LTRIMs look good and no KR is good too.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I ran atap again this afternoon and my O2's were both .905 - .910. I was looking at the wrong log for the .940 O2's. They were for my friends 96' Z. Since I got atap, I have friends coming out of the wood work! I have GMS SFC's, not the MAF. I've heard enough about the MAF that I'm staying away. I'll update the data in the first post. Any input is welcome.
Old Apr 10, 2002 | 08:57 PM
BillC99SS's Avatar
You might try reading this:
http://www.c5forum.com/diy/ltft.php
Bill
Old Apr 10, 2002 | 09:15 PM
John02SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BillC99SS:
<strong>You might try reading this:
Bill</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've got that one saved as a favorite. Very good info though.
