what afr are you running??? pole
Old Dec 28, 2005 | 12:01 PM
SlipMag's Avatar
how long do you log for? ...i am still trying to set up my ve tables....i read all the stickies... i think i am doing it correctly, but i am still unsure.....
Old Dec 28, 2005 | 12:08 PM
WS6FirebirdTA00's Avatar
when i log i let the car get to operating temp and log for at least 20 min and filter out cells with less than 25 counts
Old Dec 29, 2005 | 12:18 PM
SlipMag's Avatar
now which graph are you taking your logs from? the o2's? then do you take the difference of the graph and add them to the ve tables? just curious if i am doing this correctly....thanks for your help...
Old Dec 29, 2005 | 12:25 PM
i dont take any graphs, i use the histogram for all the fuel trims. an no you dont add. fuel trims are a % of fuel. so if you ltft and stft add up to be +10 you want to add 10% fuel to that cell (that is if this is what you are talking about)
Old Dec 29, 2005 | 02:36 PM
99sprayjunkie's Avatar
My car runs right at 12.7 on the mostly stock motor, i keep it at 12.5 on the junk.Autos and M6 cars seem to respond differently to AFR. Also, alot of people dont take into account ram air setups when setting up AFR, since u dont see its effects on the dyno.Dont want to go too lean on those bansai runs and burn stuff up!
Old Dec 30, 2005 | 08:59 AM
SlipMag's Avatar
yes this is what i am talking about.... that is the histograms i am using i just didnt know which way to go with them.... so use a calculator and do 10% of what is was and add that to it? if thats what the fuel trims call for of course... i just want to make sure i am clear...sorry for all the questions...just want to make sure i am 100% on this....
Old Dec 30, 2005 | 09:06 AM
SlipMag's Avatar
for the spray do you setup different ve tables or do you just spray the house down...? how much timing do you take away?
Old Dec 30, 2005 | 02:49 PM
BULLET99Z28's Avatar
Mods in the sig, My car on the dyno went from 13.2 gradually to 12.8 at wot, stock tune, pre shaner3 335rwhp and 342 lbs/tq
Old Jan 7, 2006 | 10:42 PM
Zeus's Avatar
ok, just to clarify, are these numbers you're getting on the dyno or on the street? I've heard cars run about .5 AFR richer on the dyno than the street, so it's nice to know which one you guys are talking about.
