When adjusting MAFT for LTFT do you have to....
Re: When adjusting MAFT for LTFT do you have to....
If you make a one click change on the MAFT to the base setting, no PCM reset would be helpful.
Any number of clicks to the WOT setting does not need a PCM reset. A change to the WOT setting probably has no learning associated with it so you should get an immediate response from the engine at WOT.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BlackWS6LS1:
<strong>An hour so wouldn't it be easier to reset it?
Let me know.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you reset the PCM, you would have to drive around for an hour, since fuel trims are a learned parm.
Let me know.
Keep in mind when you yank power from PCM
OR delete DTCs you force all I/M 240 tests back to non complete state and force the cpu of PCM to take process time away from other functions to now do those tests over where some I/M tests can take as many as 40 drive cycles to get back to a completed state.
There is no real positive to yanking power for a MAFT change, just do the 1 hour engine run time before making any further tuning judgements.
